4L60E removal hell
Old Jan 20, 2013 | 08:20 AM
newguy's Avatar
I did it with 4, 6 inch and a few 3 inch! A bit of a pain but it wirked
Old Mar 4, 2013 | 05:06 PM
IamHyde's Avatar
IamHyde is on a distinguished road
thanks for the advice. I have the tranny out now and the t/C apart an gonna replace the seals. Main pump, etc. Its a bitch. Anyone else have trouble pulling seals out?
Old Mar 5, 2013 | 05:36 PM
abig84's Avatar
sometimes. one method i always use is to drill a small hole into the seal then run a sheet metal screw into it or a lag bolt then rip them out with a pair of channel locks. but you really have to be careful as to not drill or screw into anything important
Old Mar 13, 2013 | 01:39 AM
dehackin's Avatar
dehackin is on a distinguished road
Harbor frieght sells a cheap 2ft ext and to make it a little easier toget to the top bolts i took a scissor jack put on top of trans and carefully jacked it down a little made life much easier
Attached Thumbnails 4L60E removal hell-20130310_110305.jpg   4L60E removal hell-20130310_110330.jpg
Old Mar 13, 2013 | 01:58 AM
newguy's Avatar
be carefull of your distributor
Old Mar 13, 2013 | 08:41 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Originally Posted by chestypuller
boy that dont sound right.
but id like to see it too.
Oh that one made me lol this am.I dont get how you guys have such a hard time getting those top two bolts out.Yeah its somewhat difficult but I got to mine with boxed wrench and got them out from the top.
Old Jun 30, 2019 | 11:39 PM
David Edward Rutledge's Avatar
David Edward Rutledge is on a distinguished road
Default The se
Originally Posted by IamHyde
Hey blazers, I'm having the worst time removing this "tranny" from my truck. Its a 97 blazer 4X4. (supposedly.. well deal with that later) Ive been under the truck for two weeks probably given available time from work and I have almost everything undone but a few sensors that wanna crack off an not unplug and the 11 o'clock bolt on the bell housing. Anyone out there have some tips that can make this transaction move along? Id really hate to have to sale it or spend two grand at a shop. I'm not cheap i just cant give that chunk of cash out right now. I know this is a generally expensive fix.Im nose deep in two chiltons books. One for S series and one for full size. Neither one show an exact match for mine. Whiskey Tango Foxtrot. Thanks.
"Sensor Cracking" is due to a glue used during first assembly of the transmission. Use a heat gun to heat up the area for about 30 to 45 seconds the glue will give up and let go and you can use a pick to easily remove them.
Old Jul 1, 2019 | 08:26 AM
eshaw's Avatar
Nice to know about the glue, hadn't heard of that! Which sensor are you referring to?
bubbab0909
Aug 2, 2013 02:38 AM
thisclan3
Jun 30, 2009 09:00 AM
rockfoot
Aug 8, 2008 05:16 PM
95Blazer4x4
Mar 7, 2008 07:54 PM
Jackal
Feb 15, 2007 07:18 PM
