4l60e shift problems
Old Nov 19, 2012 | 02:42 PM
Mgiudice's Avatar
Mgiudice is on a distinguished road
Default 4l60e shift problems
so i replaced my tranny in my 1996 s10 with a identical 1996 4l60e and now it shifts hard to 2nd and it just accelerates after that and doesnt set into a gear. like if you let off the gas to acelerate again you have to push the pedal all the way back down till it revs back to the correct rpm for the speed. also my spedometer and odometer are not working... please help i cant go faster than 60 without over reving my poor engine.
Old Nov 19, 2012 | 02:53 PM
Diaita's Avatar
speed sensor plugged in?
Old Nov 19, 2012 | 03:03 PM
Mgiudice's Avatar
I plugged everything in... idk where the sensor is located, is it the round plug that goes on the passanger side of the tranny at the bottom?
Old Nov 19, 2012 | 03:18 PM
newguy's Avatar
sensor is on the drivers side
Old Nov 19, 2012 | 04:09 PM
Jakeduece's Avatar
Jakeduece is on a distinguished road
Definitely sounds like speed sensor.
Old Nov 19, 2012 | 04:43 PM
Diaita's Avatar
its a 2 wire oval plug on the top rear slightly toward the drivers side of your transfer case just ahead of where the driveshaft goes in.
Old Nov 21, 2012 | 01:10 PM
Mgiudice's Avatar
oh i bet thats the problem i remember the darn plug pulled out and i thought i put it all back in correctly... can i just splice them
Old Nov 21, 2012 | 01:27 PM
Diaita's Avatar
you can splice the wires back together, if thats what you mean. or you can splice in a new plug. not quite sure what you mean, sorry...
Old Nov 24, 2012 | 12:34 AM
AydanGreen's Avatar
AydanGreen is on a distinguished road
You should not take a risk from doing from your own because you have tried it a lot and problem is going on increasing only the thing you should do know is take it to some expert mechanic who can solve your problem.
limo NJ
dj00140
22
Nov 4, 2015 05:03 AM
mattuhl30
Jul 20, 2012 10:00 AM
DrEaMsTeVe
Feb 15, 2011 02:50 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
