4L60E Transmission
Old Feb 3, 2019 | 10:53 PM
Bash's Avatar
Bash is on a distinguished road
Post 4L60E Transmission
So, after a wee bit of fun, the regrets came not long after. I might've jumped some train tracks and blown all drive gears but 2nd. Where would I be able to get a really cheap replacement for said transmission? I'm trying to get one for under $300 but can go up to $500 if needed. Thanks
Old Feb 4, 2019 | 03:15 AM
Transman304's Avatar
Sounds like the transmission is in failsafe mode. Does it have reverse? Could be electrical issue. Service engine soon light on? If so get the codes read. Good luck.
Brad
Old Feb 4, 2019 | 04:38 PM
Bash's Avatar
Brad
It does have reverse, but does not idle in any gear now without stalling. Haven't ran the codes yet, and my SES light does not exist sadly, even though its always "on"
Old Feb 4, 2019 | 06:08 PM
Find out what codes you have and we can go from there. May not need a transmission. What year you working on?
Old Feb 4, 2019 | 08:10 PM
AJBert's Avatar
If you are in the habit of jumping railroad tracks, you might want to check your frame for cracks also. As for where to find another tranny cheap, Craig's List or your local yard. Plenty of used 4l60e's out there.
Old Feb 5, 2019 | 11:07 PM
Bash's Avatar
I will look tomorrow, forgot to do so today, and its a 96
Old Feb 5, 2019 | 11:08 PM
Bash's Avatar
No habit here, it was a fun at the time thing and the only time i've jumped them, and I've killed craigslist, nothing there, and have no ride to go to my local yard yet :/
Old Feb 6, 2019 | 08:29 AM
Have you determined it to be internal problem? If it’s electrical you will still have the same issues after changing trans. There are a lot of areas outside the transmission that will put it in failsafe. Good luck.
Brad
Old Feb 6, 2019 | 03:38 PM
Bash's Avatar
Brad
I wouldn't think its an electrical problem because out of Drive, Overdrive, 2nd, and 1st, the only one that will move the car is 2nd, and it does not like to do so.
MomtheTruck'sBroke
Oct 20, 2022 12:19 PM
Daveed
May 29, 2018 10:23 PM
AlwaysWanted1
Feb 25, 2018 10:22 PM
Mickeymouse
Aug 18, 2008 11:58 AM
