4th Fuel Pump
Old Aug 6, 2007 | 05:27 AM
rsloop's Avatar
rsloop is an unknown quantity at this point
Default 4th Fuel Pump
1998 Blazer 4x4 4door.....My fuel pump I believe went bad again....Only 10psi of fuel pressure. I already had 3 installed by the local dealer ship ($1400 a pop). What troubles/stumps me is when I turn the key off I hear the pump run. Is this right. Also does anyone know where the red fuel pump test lead is that is referenced in the troubleshooting tables.
Old Aug 12, 2007 | 05:17 AM
rsloop's Avatar
Default RE: 4th Fuel Pump
Well....It's off to the junk yard for this piece of JUNK! This truck will not stay running. The fuel pump runs but it will not start. When I install my fuel pressure gage I have fuel and bust of air. I dropped the tank and the pump looks and runs ok.....I'm lost.....
Old Aug 12, 2007 | 10:32 AM
BlazerSS's Avatar
BlazerSS is an unknown quantity at this point
Make sure you have the propper gas cap on your truck. I have heard that if it isnt the right one with the the propper vaccum pressure you can go through fuel pumps like water. Also, make sure no one is dumping sugar or anything in your truck over night. Im willing to bet the gas cap is either bad or not the right one. Sounds funny but is a fact.
Old Aug 18, 2007 | 04:14 PM
brock's Avatar
brock is an unknown quantity at this point
There are three plug in lines on the pump, is it possible the two outside ones got reversed. Any of you big brains have a thought on this?
Old Aug 19, 2007 | 06:28 PM
rsloop's Avatar
It's strange....I turn the key on...I hear the fuel pump ...I turn the key off I hear the pump...I turn thr key on I DO NOT hear the pump...Off ...I hear the pump...On I do not hear the pump....What could it be....
Old Aug 19, 2007 | 07:59 PM
This sounds strangely like a failing ignition switch...
Old Aug 19, 2007 | 10:01 PM
rsloop's Avatar
Is the ignition switch the part with the key or the wire in the column
Old Aug 20, 2007 | 07:03 AM
It attaches to the ignition key cylinder. It is the electrical interface for the key cylinder in the column. Problems here can cause all sorts of weird things to happen. Run a search and read through the results. There should be a diagnostic procedure somewhere as well as a replacement procedure.
Old Aug 20, 2007 | 05:37 PM
rsloop's Avatar
Here's what I did.....When you turn the key On ... No pump ... Key off ... Have pump, etc...etc...etc...So I cycled the key a few times and the last time I turned it off and the pump ran, I quickly started it and VAROOM......Of course the pump turned off and it only ran for a short while....I ordered an ignition switch today....I subscribe to Alldata.com and went through their troubleshooting tables with no success.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
thefox1
Engine & Internal
Aug 22, 2005 10:48 PM
