4th gear help. Not going past 3rd.
Old Oct 26, 2018 | 01:42 PM
ak3394's Avatar
ak3394 is on a distinguished road
Default 4th gear help. Not going past 3rd.
I’m almost ready to give up on the blazer. I got a blazer from a coworker and the blazer has been sitting for a while. I finally get her to run and go out to test drive it. Everything is good except that it can’t go past 3rd gear! No check engine light. Only my service 4x4 light which has been on for a while. The owner did remove the old security system on the car but I bypassed it with a newrockies. I’m open for any help please! Thanks
Old Oct 27, 2018 | 11:29 PM
GreenBlazer2002's Avatar
What steps have you taken towards diagnosis?
I would start by checking the trans fluid level and condition.
Also, you said it had been sitting "a while". How long exactly? Long enough that you had to jumpstart it? If so then you haven't driven it through enough cycles to set codes yet.
Do you own a scanner of some sort? There could be pending codes.
Old Oct 28, 2018 | 03:50 AM
ak3394's Avatar
No codes. No check engine. Fluid smells a little burnt but level okay. Previous owner says the security system/ immobilizer is preventing it from shifting. I’m having doubts about that tho. (I bypassed the old security system.)
Old Oct 28, 2018 | 07:35 AM
If the ignition switch was tampered with as part of that security system then its possible. Faulty ignition switches have been known to cause all sorts of electrical problems, including shifting issues.
Old Oct 28, 2018 | 03:24 PM
Tranzman's Avatar
Tranzman is on a distinguished road
Sounds more of a mechanical fault than electrical. the transmission uses two shift solenoids for all gears. Shift solenoid "A" or "1-2"and "B" or "2-3" are identical. The ignition switch supplies power to the trans fuse, which supplies power to pin "E" at the 13 pin electrical connector at the transmission. the computer supplies the ground path for the shift solenoids. the solenoid pattern is:
  1. 1st Gear: Solenoid 1-2: ON Solenoid 2-3: ON
  2. 2nd Gear: Solenoid 1-2: OFF Solenoid 2-3: ON
  3. 3rd Gear: Solenoid 1-2: OFF Solenoid 2-3: OFF
  4. 4th Gear: Solenoid 1-2: ON Solenoid 2-3: OFF
My point is that solenoid "A" is on for both 1st and 4th. if you have first gear and not 4th the band must not be applying to get 4th. If the 1-2 solenoid didn't work or come on you would get 2nd gear starts and it would be slower to pull away and not shift till 25-30MPH. Your 1-2 shift should be at 15-20 depending on throttle.
sorry man but it sounds to me to be an internal transmission problem. I just fixed a 2000 S-10 for a similar issue 2-4 band was smoked...
Old Oct 28, 2018 | 05:05 PM
Big'n's Avatar
Big'n is on a distinguished road
Just went through this same thing a month ago. I'm praying for you brother but it cost me 3000 bucks for a new trans. Rebuild was cheaper but the ol lady likes warrantys lol
ak3394
Oct 19, 2018 05:11 PM
Jimmybeatergal
May 22, 2014 09:42 PM
madasaboxoffrogs
Dec 21, 2010 08:42 AM
WolfPack
Nov 13, 2007 09:37 PM
gstclair83
Feb 13, 2006 03:53 PM
