4x4 issues?
Hey guys, I have a 1994 Chevy full size 2 door Blazer with the 5.7 350.
It's been sitting for a while, and not driven much over the last 10 years. Motor only has 63k original miles and original tranny.
It has the manual shifting 4x4, but hasn't been shifted into 4x4 in at least 10 if not more years. I'm nervous about trying it out, anything I should do before I try it? Any fluids in front diff or anything like that?
I would check all the fluid levels to make sure they are full and then drive it to see where you are at. If everything works as it should I would change all the fluids out for new. I would take it to the wash and clean everything off (motor and underneath) and drive it. Expect to see leaks. Seals and gaskets dry out over time and this Blazer is 19 years old so you will be replacing some guaranteed.
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
BaLListic_Evo
Jun 4, 2010 03:38 PM
cmh_20
Nov 21, 2009 11:39 AM
