4x4 issues?
Old Feb 11, 2013 | 05:58 PM
Fullsizeon38s's Avatar
Fullsizeon38s is on a distinguished road
Default 4x4 issues?
Hey guys, I have a 1994 Chevy full size 2 door Blazer with the 5.7 350.
It's been sitting for a while, and not driven much over the last 10 years. Motor only has 63k original miles and original tranny.
It has the manual shifting 4x4, but hasn't been shifted into 4x4 in at least 10 if not more years. I'm nervous about trying it out, anything I should do before I try it? Any fluids in front diff or anything like that?
Old Feb 11, 2013 | 06:58 PM
Also, how can I check to see if I have any tranny seal leaks?
Old Feb 12, 2013 | 11:43 AM
grizzstang's Avatar
grizzstang is on a distinguished road
I would check all the fluid levels to make sure they are full and then drive it to see where you are at. If everything works as it should I would change all the fluids out for new. I would take it to the wash and clean everything off (motor and underneath) and drive it. Expect to see leaks. Seals and gaskets dry out over time and this Blazer is 19 years old so you will be replacing some guaranteed.
Old Feb 12, 2013 | 09:17 PM
is it alright to pressure wash (from a distance) everything under the hood?
Old Feb 12, 2013 | 09:18 PM
that a good point, I was thinking just change all the fluids then try it. if it doesn't work I would've wasted oil. im going to top off the transfer case and front diff, then try it out
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
BaLListic_Evo
Jun 4, 2010 03:38 PM
cmh_20
Nov 21, 2009 11:39 AM
