4x4 problem, new to the truck!
Old Jan 19, 2010 | 04:46 PM
youngtearz's Avatar
youngtearz is on a distinguished road
Default 4x4 problem, new to the truck!
Hi,
i just currently bought a 1999 Chev blazer, I've owned one in the past and never discovered this problem. The lady who i bought the truck off off of she had engaged it into 4hi and the lights on the switch went out.
I have checked for corrosion, i have check the vacuum lines under the battery, what else could it be. I have disconnected the vacuum line that runs to that peice under the battery, free'd up the wheels but i would like the transfer case to go back in 2hi..
any suggestions.
Old Jan 19, 2010 | 06:10 PM
Logan's Avatar
Logan is on a distinguished road
TCCM might be gone. Where abouts you located?
Old Jan 19, 2010 | 06:29 PM
3-button or 4-button switch in the dash?
Have you tried disconnecting the battery? Have you checked all of the fuses?
Old Jan 19, 2010 | 08:45 PM
youngtearz's Avatar
its the 4 button, im located in toronto canada
all fuses are good, diss connected the batt and nothing!
Last edited by swartlkk; Jan 19, 2010 at 09:06 PM. Reason: Combining Consecutive Posts - Please use the EDIT function to add additional information to your post if another member has yet to reply. Consecutive Posting is prohibited by the rules of the forum.
Old Jan 19, 2010 | 09:30 PM
youngtearz's Avatar
if it is the tccm, how much is it to fix it.. i know where its located, ive checked the wires, and there good..,
bobby099
Dec 22, 2018 09:41 PM
bigdaddykane93
Jan 27, 2016 11:35 PM
er0ck273
Jul 31, 2015 04:10 PM
2000jimmbo4x4
Aug 23, 2010 07:10 AM
cochran07
Jul 22, 2010 07:16 AM
