4x4 questions
Old Dec 14, 2007 | 07:50 PM
marc.doucette's Avatar
marc.doucette is an unknown quantity at this point
Default 4x4 questions
I just got back from brother inlaws garage.....heres the problem my 4 wheel drive has stopped working...everything worked fine no vacuum leaks and actuator is in tack....when i hit 4x4 button on dash i hear it click on right side in or by glove box which it used to do before and now the lights only flash and now i can't remember if front shaft should be turning at all times or not....also is there a relay of some sort somewheres that i should be checking and where is it
Old Dec 14, 2007 | 07:51 PM
Default RE: 4x4 questions
Old Dec 14, 2007 | 08:25 PM
*Thread Closed - Duplicate Post*
Please keep things in the first thread you created on this subject --> 4x4 front shaft
chris015
Lowering Tech
Jun 6, 2011 10:43 PM
mikejoann
Jan 4, 2010 10:23 AM
blazinwoody
Jan 1, 2009 07:38 PM
vankuen
Sep 22, 2007 05:26 PM
I8URVTEC
Jul 28, 2005 06:56 PM
