4x4 Test
Old Jul 27, 2007 | 07:58 AM
NickV's Avatar
NickV is an unknown quantity at this point
Default 4x4 Test
Hello All - I justbought a 2000 Blazer. Everything seems to work OK but I would like to be able to confirm/test that the hi and lo 4x4 is working.Any recomendations on how I might go about doing this? Thanks for any advice.
Old Jul 27, 2007 | 08:19 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: 4x4 Test
Take it out onto a gravel road so the tires can spin freely and engage the push-button. You'll be able to feel if it's working in the steering.
Old Jul 27, 2007 | 10:14 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Also you could go in a parking lot and do tight turns in 2wd, then try in 4wheel hi (do them slowly and you should be able to hear tires slipping against the pavement. and if you put it in 4 low you will notice a major difference in how much pedal it takes to get it going and how much more torque it feels like that you have. Hope this helps. Otherwise gravel would be good to see which tires are slipping. Or you could jack up all 4 corners and doing this very carefully put it in drive in 2wd and the rear wheels will spin, put it in 4 hi and both front and rear should spin, then do the test mentioned above for 4low on the ground.
-Lenny
Old Jul 27, 2007 | 10:32 AM
blazinloud's Avatar
yep, gravel road and smash it.......should have alot of traction.
Old Jul 30, 2007 | 09:41 AM
NickV's Avatar
Thanks ALL!!!
bigdaddykane93
Jan 23, 2010 02:10 PM
FlatTopFoley
Dec 17, 2009 09:25 PM
pmezo
Oct 10, 2009 03:57 PM
Scooterewski
Apr 16, 2008 09:43 PM
Labinnac
Jan 24, 2006 08:24 AM
