4x4 transmission
Old Feb 9, 2009 | 05:11 PM
dinar blazer's Avatar
dinar blazer is an unknown quantity at this point
Default 4x4 transmission
Im new here and I have A 1996 chevy blazer 4wd andits shifting up to 3rd but when it goes to shiftinto 3rd its like it drops into netrual.My next question is would a transmission out of a 99 astro van2wd fit my 1996 chevy blazer 4wd they are both 4.3 v6. I know I would have to change the tail shafts though?Thanks in advance...
Old Feb 9, 2009 | 09:50 PM
Hanr3's Avatar
Default RE: 4x4 transmission
NO for several reasons.
1) In '98 GM changed the bellhousing. It is now removeable.
2) you will have to change the output shaft and the tailhousing. To replace the output shaft you have to take the transmission apart. Not something for the average home mechanic. Find a more compatible tranny. '96-'97 4L60E 4x4 from any rear wheel drive GM truck will work. GM put the 4x4 4L60E infull size pickups, suv (suburbans, Tahoes), and vans (G10, G20)to the mid sized versions (S10 pickup, s10 Blazer, and Astro vans(including all wheel drive)), plus the GMC versions of each as well. Should beplenty in the local salvage yard.
Old Feb 10, 2009 | 06:30 AM
^^I concur^^ You will need to find a 96-97 4wd trans.
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
sfesenko
Nov 30, 2008 08:55 PM
vtlew
Jun 23, 2006 09:13 PM
96ekhb
Engine & Internal
Nov 10, 2005 07:29 PM
