4x4 Will not release om blazer-97
Old Oct 6, 2017 | 06:08 AM
Ulf Svensson's Avatar
Ulf Svensson is on a distinguished road
Default 4x4 Will not release om blazer-97
Hi. I have a blazer from 97 and hae problems with 4x4. It's vacuum to the actuator all the time and does not want to let go. what can be wrong?
Old Oct 6, 2017 | 07:21 AM
LesMyer's Avatar
If it is 4-button Auto 4WD, the two hoses on the vacuum solenoid on firewall (above distributor) may be switched (reversed) - trapping vacuum when solenoid is shut off (only one side is vented). Does the actuator release when hose is unplugged from it? Does the solenoid shut off vacuum passing through it when 2WD is selected? Note that none of this applies to 3-button 4WD (no auto button).
Old Oct 6, 2017 | 08:20 AM
It is 3 button 4WD
Old Oct 6, 2017 | 11:22 AM
Rusty Nuts's Avatar
There's a switch on the transfer case that gets stuck open causing constant vacuum at the actuator. Dorman makes a quality replacement switch part number 600-500.
Old Oct 6, 2017 | 11:26 AM
ok. Tanks.
edonwheels
Oct 23, 2023 09:21 AM
mr.vls
Mar 21, 2012 06:10 PM
hace1
Dec 6, 2011 09:34 AM
geekpower2000
Aug 22, 2011 05:19 PM
yeags
Nov 16, 2006 12:12 AM
