700r4 shifting
Old Apr 7, 2013 | 05:43 PM
r_marczak_83's Avatar
r_marczak_83 is on a distinguished road
Default 700r4 shifting
On my 86 K5 with 305 Edelbrock intake/carb, the 1st 2nd shift is really hard. Also sometimes after it shifts into OD it will stay in it for a minute then shift back and forth from 3rd to 4th.
Is this TV cable related and do I need a correction plate for the carb or should I look at something else?
Old Apr 7, 2013 | 10:20 PM
LeWhite's Avatar
1;Servo spring is broken or second aculumator spring is broken
2; are you sure its 4/3 downshift or tcc lock?
3; do you know how to adjust TV cable?
Old Apr 7, 2013 | 11:38 PM
1. It only shifts hard when getting on it. If I drive like a grandma it isnt as bad.
2. IDK if its shifting or tc lockup, but it will jerk, raise rpm's, then jerk again and be like it was at normal rpm's.
3. No I do not know anything about TV cables. I have just tried to look up stuff before I asked on here and I found a lot of articles related to it.
Old Apr 11, 2013 | 07:49 PM
Did that help?
Old Apr 12, 2013 | 07:13 PM
I got a correction kit but it will not work. It puts the cable out to the drivers side and that is too much of an angle.700r4 shifting-picture-011.jpg700r4 shifting-picture-010.jpg
96jimmy4x4in
Oct 7, 2007 09:23 PM
ToplessK5
Apr 23, 2007 12:16 AM
oldsledman
Apr 11, 2007 01:27 AM
oldsledman
Apr 6, 2007 05:29 PM
