75' Transmission problems
Old Jul 18, 2014 | 06:36 PM
W1Ll3's Avatar
W1Ll3 is on a distinguished road
Unhappy 75' Transmission problems
Hey!
I've got at little problem with my 1975 K5 blazer 4x4, automatic. Problems begun after parking at the beach, 2 hours later I put it in reverse and then in drive, but it would not move. More or less like N. Had to be towed away...
Problem still stands, I can go backwards but not forward. Tried moving the H(loc)-H-L-L(loc) shifter but did not help at all, no gears worked at all in any other position than H, and there was some leakage from the transmission aswell...
Help would be appreciated, thanks in advance!
//Greetings from Sweden
Old Jul 20, 2014 | 02:21 PM
Beatrice79's Avatar
Beatrice79 is on a distinguished road
Sounds like you have a bad transmission. When was the last time you had a flush, or a rebuild done?
Old Jul 29, 2014 | 08:18 PM
Tranzman's Avatar
Tranzman is on a distinguished road
Try manual low, if it moves then you have a blown Low roller. If it doesn't move then you have either a blown gear train or a broken sun shell. All of these require a transmission overhaul. You could pull the pan off and see if there is a bunch of metal debris in the bottom. I have overhauled more than a few 350 Turbos from a full sized Blazer with broken hard parts.
I see your from Sweden, I'm not sure of parts availability over there for the 350. I still have some parts, so if I can help... let me know.
GloryImSaved
Jul 17, 2009 09:05 PM
upblazer95
Apr 4, 2009 08:27 PM
sfesenko
Dec 12, 2008 10:03 AM
vtlew
Jun 23, 2006 09:13 PM
SniperX13
Mar 21, 2006 04:02 PM
