82 K5 Turbo 350 Leaking into NP 208
Old Oct 13, 2010 | 11:24 AM
82k5blazer's Avatar
82k5blazer is on a distinguished road
Arrow 82 K5 Turbo 350 Leaking into NP 208
I have a 82 K5 that is leaking dexron through the adapter into the NP 208.
I dropped the transfer case and inspected the back end of the transmission and the front of the transfer case with the adapter on it.
I'm wondering..... where are the seals that prevent the fluid from flowing from the Turbo 350 into the NP 208?
I've done some digging around on google and a few forums to no avail.
Thanks in advance!
Daniel
Old Oct 13, 2010 | 11:28 AM
The seal is located on the very front of the transfer case. If you removed the adapter with the transfer case, you must then remove the adapter to gain access to the seal.
Old Oct 13, 2010 | 11:31 AM
82k5blazer's Avatar
Awesome! Thanks for the quick reply! I'm about to go check it out in a moment. Also, is there a seal on the back of a 4wd Turbo 350 at the the output shaft? My reading online and in Ron Session's THM 350 Handbook points to no. Is this correct?
Thanks,
Daniel
Old Oct 13, 2010 | 11:34 AM
There is no output seal on the back of the transmission.
Old Oct 13, 2010 | 11:38 AM
82k5blazer's Avatar
Thanks!
Daniel
Old Mar 5, 2011 | 08:12 PM
will_hey83k5's Avatar
will_hey83k5 is on a distinguished road
Question turbo 350 leaking into 208 t case
is there no seal in the rear of the turbo 350 because the little hole at the bottom leaks into the t case to keep it lubed if so do you just fill the transmission until it is correct and then the t case will be at the correct fill point
Old Mar 6, 2011 | 12:13 PM
abig84's Avatar
Basically. After you repair the seal on the transfercase. Just fill them both to where they are supposed to be. Don't forget to silicone where the 2 mate together when you put them back together
Old Mar 6, 2011 | 11:18 PM
Question
chris015
Sep 17, 2011 07:31 PM
lopez9021
Mar 30, 2010 09:26 PM
alstonfered
Jan 28, 2010 06:27 AM
quinn1991
Sep 27, 2009 09:31 PM
georgia_boy79
Jun 14, 2009 09:04 PM
