83 K5 blazer 4x4 Transmission bangs into gear at idle
Old Mar 10, 2021 | 10:21 PM
Rustyrod's Avatar
Rustyrod is on a distinguished road
Default 83 K5 blazer 4x4 Transmission bangs into gear at idle
My 83 K5 with a 700r4 slams/bangs into gear at idle. It has been sitting for 5 years, but fired right up and other than the hard shifts, it seems to drive fine.
Ideas?
thanks
Old Mar 11, 2021 | 05:13 AM
Transman304's Avatar
First thing I would look at is excessive driveline play. Bad motor, transmission mounts will also give you those symptoms. Check the TV pressure cable for smooth movement through the full travel of the throttle arm.
Brad
Steve-o
Aug 20, 2011 10:19 PM
safir
Mar 25, 2011 03:27 PM
jetexpress12002
Dec 24, 2010 03:27 PM
75 blazer
Aug 13, 2010 06:36 AM
joeewhite
May 22, 2010 07:43 PM
