87 k5 stall while making slow turns
hey guys, my 87 k5 350 tbi recently started stalling while turning at slow speeds {like turning into parking spot speed}. Could this be a fuel pressure issue? Truck runs great at full speed, also stall sometimes while in reverse. thanks
That would also give me. Surging while idling ,but smooth out once i give it gas right? When i come to a stop it stumbles and idles down really low like its gonna shut off but stays running. Ill try the vacuum leak thing. Thanks
speaking of vacuum leaks. check your egr valve also. friend of mine brought his truck over for a similar issue and his egr was opening wide open at low rpms causing it to die out. disconnect that SOB, plug the line and drive it see if that fixes it
ComputerNerdBD
Feb 29, 2012 08:09 PM
musclecar70sfan
Nov 7, 2010 08:48 PM
magsmom
Feb 19, 2009 11:57 AM
Lockback
Aug 22, 2007 12:24 PM
rooster
Jun 7, 2007 08:40 AM
