92 Blazer s10 will not stay in park
Old Jul 12, 2011 | 02:37 PM
chevroletfan's Avatar
chevroletfan is on a distinguished road
Default 92 Blazer s10 will not stay in park
Hello friends,can somebody help with this problem.
Old Jul 12, 2011 | 02:38 PM
Improperly adjusted shift linkage? What have you tried to correct the issue?
Old Jul 18, 2011 | 09:52 AM
Default 92 blazer will not stay in park
changed and top up trans.oil try to fool around with the linkage but no good results,sometimes it stays in park,but mostly dont,also ghange or replace the body mounts on driver and pass. side as this were collapsed.
thanks for reply.
Old Jul 18, 2011 | 09:57 AM
I still think it is a shifter adjustment. The way you adjust the shifter is to back off on the adjustment all the way (or unlock it depending on what type of linkage/cable you have). Manually put the transmission into park. Then tighten up the adjustment nuts onto that position (or lock the adjustment if it's a cable with plastic adjustment piece at the mount on the trans). Then operate the shifter through all of its locations to verify that it goes in properly.
If yours is old enough to have a linkage, I have seen a number of linkages get twisted over time causing them to not have the proper range for full operation of the transmission. If that is the case, you'll have to take things apart and bend the arms back or get a replacement from a junkyard.
blazintheway
Sep 5, 2013 08:29 AM
thays0407
Mar 8, 2011 03:55 PM
republic
May 15, 2010 10:15 PM
mbellhy
Feb 15, 2010 02:20 PM
millertimee
Mar 24, 2008 01:32 PM
