92 Chevy S10 Blazer
92 Chevy S10 Blazer
My blazer has been over heating and everyoneI've asked said it's probably the thermostat. Anyoneableto f give me a general location of my Thermostat ? [/align][/align][/align]Thanks in advance[/align]
RE: 92 Chevy S10 Blazer
Follow the upper hose off of the radiator. It will be on the driver's side of the radiator. Where it goes into the engine, the thermostat will be located under the fitting that the upper radiator hose connects to.
Thanks Swart! [sm=hail.gif][/align][/align]I Found the the thermostat by following the hose like you said but now i need to get the radiator hose off . What is the best way to drain all the fluid out of the radiator hose ? [/align]
If you can get to the drain in the passenger side radiator tank, that is the preferred method of draining the radiator. But the other method is to remove the upper fan shroud, and remove the lower radiator hose from the water pump inlet. Do it from the top! Trust me! You'll be bathed in coolant if you do it from underneith! Just be aware that this will make a rather large mess regardless of how big of a drain pan you have under the truck!
Ok got all done and staring at the metal piece that is connected to the thermostat . All i got to do now is unbolt that and put a new thermostat in. [/align][/align]Thanks again Swart ![/align]
ChevyMane808
04-05-2013 10:51 AM
celchlepp
01-10-2008 01:24 AM
