92 s10 blazer - 4 wheel drive problems
Just recently me and my girlfriend bought a blazer for $1,000. I test drove it and it seemed to get around just fine. Well after we took it home i saw that the 4 wheel drive was on. I turned the 4 wheel off and wasn't even able to get it out of my driveway. So i tried to put it back in 4 wheel drive and no go It has the toggle switch on the dash. (Up is 4hi, Down is 4low). The switch just wouldn't do anything, no lights, no 4 wheel drive. We called the guy and asked him if he knew anything about this and he said that he'd been driving it around in 4hi all winter. So i checked the actuator under the battery tray, it's good. Swapped the dash switch out with one from the junk yard. Replaced the switch in the transfer case. and then it worked perfect for about a day. Now I'm back to the same problem, push the switch and nothing happens, no lights, no 4 wheel drive. Usually when i push the switch you can here it engaging and stuff. But I'm getting absolutely no response.
Could it be the dash switch?
I've looked all over the Internet, searched multiple forums (including this one). It seems plenty of people have had this problem, or problems like it. But i can't seem to find the solution.
If anybody can give me any sort of help it would be greatly appreciated. Iowa winters are rough and we need the 4 wheel drive in this truck to go to work and back.
Thank you.
-Kodie
Update: I've read a little bit about the TCCM (Transfer Case Control Module) being a possibility to my problem though haven't found much information about them. Does anybody know much about these?
Thank you.
-Kodie
So i don't know what would be causing this but apparently my truck needs to be warmed up pretty good before the 4 wheel drive will kick in? Haha.
Anybody know what could be causing this?
mirrorimij
Jun 8, 2019 03:34 PM
drnwoody
Jan 26, 2013 05:38 PM
randrm
Jan 25, 2011 02:51 PM
lizzj70
Jun 23, 2010 06:57 PM
