94 S10 Blazer drivability issues
Old Jan 20, 2015 | 01:47 AM
94S10Blazer4x4's Avatar
94S10Blazer4x4 is on a distinguished road
Default 94 S10 Blazer drivability issues
My fiance and I have a 94 S10 Blazer with the 4.3 Vortec. I have to give it gas to get her to start up, she idles rough, new plug wires, but fouled plugs, and a few vac leaks. What is the best cheap plugs to get, and what do I gap them to?
Old Jan 20, 2015 | 04:17 PM
GoldOlds94's Avatar
GoldOlds94 is on a distinguished road
ACDelco CR430 gap 0.45. I think the fuel injector unit is your problem aka (spider unit).
Old Jan 21, 2015 | 01:14 PM
that was my first thought, but we arent getting a gas smell from the block. putting in new plugs got rid of the raw gas smell from the exhaust, had a friend listen to me start it up, he says fuel pump is going bad. its loud, and cuts off after about 2-3 seconds (not sure if thats supposed to happen, but its possible) Runs fine after about 25 mph, but shuts off if i keep it in drive when stopped.
Old Jan 21, 2015 | 02:15 PM
LeWhite's Avatar
The fuel pump 'primes' the fuel system but not the motor for two to three seconds at initial key on.
Old Jan 21, 2015 | 05:44 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
94 may be an OBD 1 so im not sure checking codes will tell you much but you should still check fuel pressure at the test port and the fuel filter outlet. definitely sounds like a pressure or leak down problem. And you really don't want to use cheap plugs or any cheap tune up parts in these engines. They are very sensitive to this and you should only use AC Delco parts. That's not a sales pitch it is just the cold hard truth..
Old Jan 22, 2015 | 09:51 PM
Getting a fuel filter first. Going to see if that fixes anything first.
Old Jan 23, 2015 | 10:46 PM
GoldOlds94's Avatar
My motor would hesitate an run like it needed more gas Once in a while. At first I thought it was a clogged fuel filter. So I replaced it and everything seem to be just fine for about three months. One day it wouldn't start i notice fuel pump was not making its wining sound. Switched out the relay switch an it's started. Then about two weeks later it happen again an stayed that way. Replaced fuel pump an it solved the problem for good. I was shocked to fine out that all the wires on old pump where burnt badly. I hooked it up outside of tank and it smoked an sparked. If there was oxygen in my tank my car would have caugh Fire. Long story short. Replace the fuel pump it's only $100 it might save you from something bad happening.
Old Jan 24, 2015 | 12:28 PM
richphotos's Avatar
94 s10 blazer is obd1.
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
Crazyc775
Jun 10, 2012 07:52 AM
cruukedeye
Jun 4, 2011 06:49 PM
celchlepp
Nov 18, 2008 11:16 AM
