94CPIBLAZER rough idling new injecter
Old Jul 13, 2023 | 04:16 AM
s10blazerman's Avatar
s10blazerman is on a distinguished road
Default 94CPIBLAZER rough idling new injecter
Hello,
I am having trouble with idling malfunction.
I have replaced many parts.
Spider injectors, IAC, EGR, distributor, ICM,fuel pump, fuel filter, fuel tank, spark plug, plug wire intake no fuel leak, new ecm
No fuel leak in upper intake Fuel pressure is about 58 to 62 psi
From 62psi on key on to 25psi immediately then slowly to 0. Is this normal?
Please give me your wisdom.
thanks
Old Jul 13, 2023 | 11:00 AM
GeorgeLG's Avatar
You need to identify the cause for the fuel pressure leak down. Look at the sticky on testing fuel pressure and get the leak down reading at the fuel filter. This tells us if the problem is in the tank or at the engine.
George
Dolanjohn1990
Suspension Tech
Mar 18, 2015 02:34 PM
01blazer16
Lifting Tech
Jun 21, 2013 06:32 PM
01blazer16
Lifting Tech
Jun 14, 2013 04:49 PM
corner27
Oct 27, 2010 05:44 PM
Fatherof5
Jun 14, 2010 08:22 PM
