95 blazer 4x4 4.3 vortec transmission?
Old Dec 8, 2008 | 12:50 PM
dabricks's Avatar
dabricks is an unknown quantity at this point
Default 95 blazer 4x4 4.3 vortec transmission?
my blazer will drive but soon as it tries to shift loses all power if u turn it off then turn it back on it will engage again till it tries to shift any clues?
Old Dec 8, 2008 | 02:49 PM
LannyL81's Avatar
Default RE: 95 blazer 4x4 4.3 vortec transmission?
Are you saying that when you take off with gear selector in D or Over D, that it looses power when its time to shift from 1st to 2nd?
Or if you take off in 1st and then manually go to 2nd, do you lose power?
Trying to better understand your problem.
Old Dec 8, 2008 | 07:13 PM
dabricks's Avatar
when i stick it in drive it runs through it till it tries to shift the loses power if u turn off truck start it back up it will do it again im not manually shifting dosent work either though
Old Dec 11, 2008 | 11:53 PM
CoolAirVw's Avatar
CoolAirVw is an unknown quantity at this point
Is it neutraling on the 2-3 shift? Direct clutch failure is common.
mrblonde108
Jul 17, 2017 07:52 PM
ussexplorer
Mar 31, 2014 09:00 PM
mitch_houser
Jun 12, 2010 01:12 PM
debo42
Sep 14, 2009 06:34 AM
96blkblazer
Feb 26, 2009 04:29 PM
