95 Blazer, Coolant Leak, Intake or Head Gasket?
Old Apr 24, 2009 | 06:32 AM
nova72's Avatar
nova72 is on a distinguished road
Default 95 Blazer, Coolant Leak, Intake or Head Gasket?
Hi, I have a ’95 Blazer with a 4.3L Vortec V6. The engine has developed an internal coolant leak. No external leaks are visible. A considerable amount of white smoke comes out of the exhaust. The coolant level drops and there appears to be coolant dripping out where the right exhaust manifold mates to the Y-pipe. I pulled the right side plugs. The #6 plug appeared to have a little more buildup on it but all appeared dry. I cranked the engine over, but nothing came out of the plugholes. The question I have is, could this leak be from the lower intake manifold gasket or a head gasket problem or worse? Thanks!
Old Apr 24, 2009 | 07:02 AM
A LIM gasket leak could allow coolant into the cylinders.
Coolant intrusion into the cylinder will actually result in the plugs being steam cleaned.
You can run a compression test to see if you have signs of a head gasket problem. You can also pressurize the cooling system up to 16psi and look/listen for leaks.
limited edition 1
Jan 27, 2023 11:07 AM
Melrock83
Jul 3, 2012 06:51 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
