95 Blazer intermittent ticking noise
Old Aug 7, 2012 | 08:00 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Default 95 Blazer intermittent ticking noise
Sorry I can't find my old thread but I'll be brief. Problem started out as a loud Chirping Noise then a slight ticking noise at Idle. I thought the noise was coming from the Flywheel/Torque Converter area. The Tranny has 427,000 original miles,so I took it to a tranny shop they dropped the tranny rebuilt it and replaced the TC and Flywheel. The Chirping is gone but there is an intermittent ticking noise at Idle Sounds like it's coming from under the upper Plenum when under the hood and when under the car sounds like the Flywheel area, Anyone have any idea what it might be? the truck runs smooth and the noise comes and goes Please Help
Old Aug 10, 2012 | 12:32 PM
matthewp's Avatar
matthewp is on a distinguished road
I don't how miles your engine has on it, it could could be a valve related problem like a hydralic lifter failing. 4.3L Vortecs are push rod engines, so your camshaft and lifters are in the middle of your engine which would explain why you can hear it from the top and the bottom of the engine.
Killah_K
Jun 21, 2010 04:35 PM
bammontana
May 9, 2010 12:53 PM
mmagana
Jan 9, 2010 08:18 PM
breakyadown89
Oct 17, 2009 11:45 PM
pmezo
May 16, 2009 12:18 AM
