95 Blazer not starting
Old Oct 28, 2011 | 02:23 PM
caine_mcmaster's Avatar
caine_mcmaster is on a distinguished road
Default 95 Blazer not starting
after 2 weeks of working on it still wont start. Checked the timing and its fine. Replaced the crank timing sensor. Replaced the plugs because they were fouled and over spaced. replaced Coil and engine control module, replaced the ignition switch also. After all that it is now trying to start but is backfiring and dieing.
Old Oct 29, 2011 | 11:01 AM
DaveLT19's Avatar
DaveLT19 is on a distinguished road
sounds like maybe a fueling issue, maybe try changing the fuel filter if you hear the pump still trying to work. Or take the filter out all together and prime the pump to see if the pump is working at all?
Old Oct 29, 2011 | 02:02 PM
xgiovannix12's Avatar
follow this
https://blazerforum.com/forum/tech-a...agnosis-23038/
thats the best way to diagnose the fuel system
stschuyler25
Nov 21, 2010 09:34 AM
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
chrisoaf
Oct 1, 2006 01:22 AM
Im_Bryan
Mar 29, 2005 01:20 PM
