95 blazer running rough
Old Oct 5, 2012 | 07:11 PM
keegan's Avatar
keegan is on a distinguished road
Default 95 blazer running rough
Have 4.3 and is runs for a minute then runs rough until it dies replaced injectors and fuel filter when you step on gas is stalls and sputters computer shows 1.5 then goes to 4.0 on fuel until it stalls out
Old Oct 6, 2012 | 11:46 PM
cleburne red's Avatar
Kinda going out on a limb, but have you checked your MAP sensor? I was having a similar issue, and it turned out to be the MAP. Will it idle until you open the throttle?
Also, what are the codes? If you have obd 1, it's as simple as using a paperclip. obd 2, and Autozone can do it. If you are unfortunate enough to have obd "1.5", it's going to be tough.
blazerguy22
Nov 14, 2013 11:50 PM
ksimpson
14
Oct 7, 2013 05:25 AM
nhguy261
Dec 30, 2010 01:41 PM
88s10Blazer
Dec 31, 2009 05:30 PM
93LT
Mar 11, 2006 01:56 AM
