95 Blazer tranny
Old Jun 8, 2009 | 12:35 PM
medwards22's Avatar
medwards22 is on a distinguished road
Default 95 Blazer tranny
Hello every one. I have a 95 blazer and i am replacing the transmission in it. I am having trouble unbolting the top bolts and was wondering if any one had a suggestion or easy way to do it. I tried to get it from the bottom and the top. there is a wire harness and some lines in the way from the bottom. The tranny is a 4l60 2wd. Thanks
Old Jun 8, 2009 | 10:29 PM
The easiest way is from the bottom with ~4' of extensions and swivel sockets. You have to drop the back of the transmission down and then move the wires out of the way.
Old Jun 9, 2009 | 09:50 PM
fondo's Avatar
fondo has a little shameless behavior in the past
No fun at all but doable. I had to remove a tranny from a blazer that had been punched hard in the front. Almost ended up cutting an access hole through the top (considering the truck was junk anyway) but ended up coupling a few long 1/4" extensions together along with a 14mm swivel socket (1/4" drive) and was able to just barely fit through what little space was left. That sucked!! Good Luck.
Old Jun 11, 2009 | 08:19 PM
medwards22's Avatar
Thanks for the reply's. Had to go out and buy the extensions but i got it out.
Old Jun 11, 2009 | 08:22 PM
Extensions are always nice to have around anyway. Money well spent!
I am glad you got it done!
jjstyle
Jul 29, 2014 06:53 PM
PogiMoto
Jun 2, 2014 11:31 AM
ski.dive
Feb 7, 2014 05:18 AM
wildcatxcr8
Jun 23, 2006 09:36 PM
nine5blazer
Oct 18, 2005 05:19 AM
