95 blazer trans leak
Old Nov 6, 2020 | 01:27 AM
Atossedsalad's Avatar
Atossedsalad is on a distinguished road
Default 95 blazer trans leak
Ok so I noticed I had fresh trans fluid by the bell and the transfer case. It was not dripping just a couple thin wett spots. The spots were not there before. Last time I worked on it was almost 2 weeks ago and no leaks. So upon finding wett spots, I did a little looking around and found a missing transmission mount bolt on the clam shell. Could that be the reason for the leaks at bell and transfer case? I'm also not 100% on the bell leaking but there's just fluid up there so I'm assuming. Please anyone with some words of wisdom. Also idk if this helps but I'm no certified tech but I'm pretty handy on vehicles. I do all my own work. As long as it dont involve going inside the motor or anything past shift solenoids in the transmission. Other than that I've pretty much done it lol
hype56
Sep 28, 2017 03:25 AM
kuntryrebel88
Nov 3, 2015 10:46 PM
Mjseyler
Jan 5, 2010 12:44 PM
pbrew
Apr 30, 2008 12:11 AM
Loofah
Apr 28, 2008 11:38 PM
