95 blazer transmission
Old May 10, 2012 | 02:27 PM
gooch's Avatar
gooch is an unknown quantity at this point
Default 95 blazer transmission
95 blazer tranny (4l60e) what other years can you swap out with and will the bolt together bellhousing style trannys interchange with the solid tranny housing?
Old May 10, 2012 | 03:07 PM
gooch's Avatar
ok i think i fig out my question as long as it says pwm on the pump housing? ok i just come back from checking this other tranny out the bell housing is my only issue everry thing else looks like it will work. the differents is the housing my is all one housing and the one i looked at the bell housing bolts on the housing wraps all the way around the torque converter to where the one with the one housing has a big dust pan that bolts on. will i have a problem swapping these to trannys out?
JZS005
Dec 29, 2009 10:33 AM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
sfesenko
Nov 30, 2008 08:55 PM
96ekhb
Engine & Internal
Nov 10, 2005 07:29 PM
