95 Blazer won't shift past second
Old 02-02-2011 | 12:59 AM
sbleier's Avatar
sbleier is on a distinguished road
Default 95 Blazer won't shift past second
My daughters car developed a shifting issue. When you put it in OD, it goes from 1st to 2nd and then appears to go into neutral before going back to 2nd.
I can manually shift it into 1st or 2nd but when I put it in D, it acts like Neutral.
I noticed a vacuum line cut under the transfer case. Repaired it - no change.
I disconnected the battery to get at the vacuum line - not sure if that had any influence. I hate to replace the tranny if it is something else less expensive. Fluid level was a little low. Added a half pint. I think it looked clean but need to re-check. Prior to this, it shifted OK, but you had to let it warm up for a minute before it would shift OK.
Old 02-02-2011 | 07:23 AM
*Moving to Engine & Transmission* - Technical questions belong in the appropriate technical section. Please read the descriptions of the sections and choose the one that best describes the nature of your question.
Old 02-02-2011 | 08:51 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Check the fluid condition. I'm betting a rebuild is in the near future. How many miles on vehicle?
Old 02-03-2011 | 10:12 AM
sbleier's Avatar
Default Blazer w/shift issues
The vehicle has 133K, which I would think is low for tranny issues.
chcknugget
11-26-2013 03:24 PM
texas4x4blaze
07-16-2010 08:51 PM
2KBVDA
10-30-2008 03:52 PM
dimone545
09-03-2008 08:25 AM
96Ls4Dr
02-06-2007 05:28 PM
Quick Reply: 95 Blazer won't shift past second
