'95 Jimmy 4x4 Bad Acceleration
Old Jul 20, 2017 | 09:07 PM
  #51
ChuckNTruck's Avatar
Originally Posted by Tynan Tha Real Dill
My fuel line has been leaking fuel for an hour now, how do I stop fuel from coming thru the lines? I pulled the fuse, relay, removed gas cap, and disconnected the negative battery terminal. Am I missing something or how can I stop it? I can't continue to cut with it leaking like that or should I let it drain all out?
Hose is lower than the fuel tank. Gravity is doing its job.
It will either stop when the fuel tank is empty or In the past i have taken a length of rubber hose and blew air into the line to push all the fuel back into the tank.
Old Jul 20, 2017 | 10:03 PM
  #52
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
what happens if I just cut it where it connects to the filter with wire cutters?
Old Jul 21, 2017 | 04:37 AM
  #53
newguy's Avatar
you are replacing the filter also ,Right?
Old Jul 21, 2017 | 07:23 AM
  #54
Yes if needed, I think the filter is good but I'm not sure how to check it. Do u think it needs to be changed?
Old Jul 21, 2017 | 08:42 AM
  #55
The line is finally cut
Old Jul 21, 2017 | 09:29 AM
  #56
Ok looks to me like the end of the filter with the twisted line on it, is slightly bent upward. May need a new filter.... Also I noticed, where the twisted line was connected, which is the line that shoots fuel from the gas tank, it's say "OUT" on it... Was this filter put on backwards??? Fuel from the tank shoots fuel "IN" from that direction, not out!
Attached Thumbnails '95 Jimmy 4x4 Bad Acceleration-20170721_090550.jpg   '95 Jimmy 4x4 Bad Acceleration-20170721_090607.jpg   '95 Jimmy 4x4 Bad Acceleration-20170721_091555.jpg
Old Jul 21, 2017 | 02:19 PM
  #57
chevy77's Avatar
chevy77 is on a distinguished road
1. i would replace that filter either way they are cheap
2. it says "out" so you know which direction to install the filter if you put it on backwards it will not run correctly
Old Jul 21, 2017 | 08:55 PM
  #58
What's the size wrench is the tubing bolt and filter bolt ? I have it all together, just need to tighten it down...
Old Jul 22, 2017 | 10:05 AM
  #59
chevy77's Avatar
it's been awhile but i believe the line nut is 5/8 and the filter side is 13/16 try to use line wrenches if you can less chance of rounding them off
Old Jul 22, 2017 | 10:29 AM
  #60
newguy's Avatar
hers an idea, try different ones till you find the one that fits!
