95 S-10 Blazer distributor differences
Old Mar 28, 2011 | 10:06 PM
pjs66lane's Avatar
pjs66lane is on a distinguished road
Question 95 S-10 Blazer distributor differences
What is the difference between side mounted spark plug wires on the distributer and the top mount? Are they interchangeable? When I search online for an engine it specifically asks which one I have. It is a "W" code on the VIN. Any experts out there?
Old Mar 29, 2011 | 06:50 AM
They are not interchangeable. One is for the EDI system and the other is for the older more HEI style. Both systems were available in '95 and any parts catalog should give both options.
Old Mar 29, 2011 | 11:35 AM
pjs66lane's Avatar
SWARTLKK, Thanks for the reply! Now my question would be to you or anyone who knows. Can I swap engines that appear identical between a 94 bravada and the 95 Blazer by just tranfering the distributor from one block to the next, essentailly leaving the origional dist. intact?
Old Mar 29, 2011 | 11:38 AM
The EDI engine requires a CKP (crankshaft position) sensor. If the older motor does not have provisions for the CKP sensor, you cannot use it without investigating swapping over parts. I am not sure what can and cannot be swapped between them.
MJ176
Nov 14, 2013 06:02 PM
jsmurphyphone
Jan 21, 2011 07:54 PM
stephensh
Jun 21, 2010 03:42 PM
mscott03
Sep 12, 2006 09:09 AM
KA3AX
Apr 6, 2006 07:52 PM
