98 to 01 blazer knock sensor differences ?
Old Jul 24, 2013 | 06:03 PM
MJ176's Avatar
MJ176 is on a distinguished road
Default 98 to 01 blazer knock sensor differences ?
Hi, i have a question on an engine swap, the 98 models have a one wire crank sensor, and the 2000 and up have a 2 wire sensor.I have installed a couple of the newer engines in the older models and just drilled and tapped the hole for the knock sensor, seemed to work fine.The question i have is i want to install the engine from a 98 into a 2001, the 98 block has the bigger hole in it but the 2001 crank sensor just takes a small bolt, what are the options i have to make the 2 wire sensor fit the 1 wire sensor block?Any help would be appreciated, Thanks
Old Nov 14, 2013 | 06:02 PM
bobthehunter60's Avatar
bobthehunter60 is on a distinguished road
Default knock sensor
you will have to have an adapter machined . i had same problem built an adapter . works fine .
fredguaz
Dec 11, 2017 08:11 AM
deathman
Oct 6, 2010 11:25 PM
ejschultz
May 23, 2009 04:15 PM
deadpool
Apr 2, 2006 06:09 AM
dwoftx
Jul 10, 2005 06:47 PM
