So i just bought a 95 blazer with burnt up 3-4 clutches thinking id just get a junk yard unit and slap it in..well i didnt realize the 95 was a one off year and now im looking a 950+ for a rebuild. Is there anything i could do to swap in a newer year? Swap plugs on harness? Also i have a 4 bolt dust cover and im only finding 95's with a 6 bolt dust cover. What is the difference? Thanks for any help
The 4 bolt dust cover is for 2wd vehicle. The 6 bolt cover is for 4wd. Is your blazer 2wd? If not it has been changed at some point. The steps required to make a newer unit work is very costly and time consuming unless you are quite familiar with transmissions. Good luck.
is there a way i could measure driveshaft length to tell whats going on? I just pulled the transfer case last night
There is no dimension difference at all in transmissions You can use your 4 bolt cover on a 6 bolt case just have to drill cover for larger diameter bolts.
wow thats a game changer. Ive had people telling me a 6 bolt wouldnt work.
