96 4wd blazer wont pull
Old Jan 31, 2016 | 10:25 AM
nealw's Avatar
nealw is on a distinguished road
Exclamation 96 4wd blazer wont pull
I have a 96 4wd blazer that wont pull in any gear. I let a friend use my blazer on his farm to pull a trailer with hay on it. He was using 4x4 mode pulling the trailer loaded. He said he heard a loud pop and now it wont pull. It acts like it is in neutral. I cant afford to take it to the shop. I am mechanically inclined so I work on my own vehicles. so if anyone knows what the solution to my problem is please let me know. I really would like to be able to drive my blazer again . It has only 138000 miles on it
Old Jan 31, 2016 | 10:35 AM
Red Sled's Avatar
Red Sled is on a distinguished road
Sounds like he OVERLOADED THE TRANSMISSION. ITS TOAST .02
Old Jan 31, 2016 | 10:46 AM
nealw's Avatar
thank you, someone told me that the transfer case could have went completely out but I'm not sure of anything cause it has all the computer selonoids and relays
Old Jan 31, 2016 | 10:53 AM
Red Sled's Avatar
Maybe one of the heavy hitters will chime in but ive BLOWN up a few transmissions that went that EXACT way POP!!!!
Old Jan 31, 2016 | 10:58 AM
nealw's Avatar
ok again thank you. I wasn't in the vehicle when it done it. so it looks like I will be replacing my trans. would my transfer case be ok to reuse on the new tranny?
Old Jan 31, 2016 | 11:01 AM
Red Sled's Avatar
Thats where someone with more knowledge chimes in How many pounds we talking as far as this hay trailer +-
Old Jan 31, 2016 | 11:10 AM
nealw's Avatar
I'm not sure on what the round bales of hay weigh. I guess around maybe 4000 to 5000 lbs. he had my blazer towed back to my house.
Old Feb 2, 2016 | 03:27 AM
Could be more things.
When pulling the trailer has he been in 2HI or 4HI or 4LO? What are the RPO codes on that Blazer for the trailing options? Trailer package? Trans oil cooler/heat exchanger?
Transfer case chain rupture Would do the same as now it is kinda in neutral.
Transmission. Does reverse work?
Torque converter? Overheated?
Drive shaft in the rear axle? But it would still pull in the front. Never heard of a Blazer brake the shaft anyway.
Old Feb 2, 2016 | 01:27 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Flywheel?
https://blazerforum.com/forum/engine...acement-18861/
dj00140
May 20, 2013 06:37 PM
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
96ProjectHighLife
May 1, 2010 10:07 AM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
