96 blazer Transmission problem
Old Nov 6, 2019 | 03:35 PM
Czechman90's Avatar
Czechman90 is on a distinguished road
Default 96 blazer Transmission problem
I am in the middle of trying to replace some dash lights and my transmission wont shift down to first gear, so i can take the dash out. It only goes to overdrive and then stops there. My dad did tell me the transmission was replaced as long with motor. Could be the vss or something differnt.
Old Nov 6, 2019 | 05:53 PM
Transman304's Avatar
Sounds like the shifter cable is not adjusted properly. Easiest way would be to go under and pop the cable loose from the transmission. Complete your dash work and then pop it back on. May want to look into getting it adjusted properly.
Brad
Old Nov 7, 2019 | 06:27 AM
Czechman90's Avatar
I will try to see what the shifter cable looks like under the hood. Hopefully i dont have to replace something.
Tynan Tha Real Dill
Sep 11, 2017 04:56 PM
Night_Wolf
Dec 24, 2013 06:32 PM
jwalker1992
Jul 19, 2012 05:24 PM
my95blazer
Apr 2, 2011 04:28 PM
LannyL81
Dec 27, 2008 02:04 PM
