96 Blazer wont stay running
Old Apr 8, 2018 | 03:48 PM
Nussbaum0906's Avatar
Nussbaum0906 is on a distinguished road
Default 96 Blazer wont stay running
My 96 blazer wont stay running i have done a full tune up the spark is good fuel pressure is right around 55 60 psi i have changed map sensor and maf sensor as well put in a new battery. It will start but bogs down and dies shortly after if i feather the throttle itll stay running but if i let off itll die after a few minutes
Old Apr 8, 2018 | 07:28 PM
Throttle position sensor bad? Codes?
Old Apr 8, 2018 | 07:44 PM
I put a snap on scanner in it its saying no response from module. Check engine light isnt on either so im not sure about that but i havent tried that one yet
Old Apr 25, 2018 | 03:03 AM
Edz's Avatar
Edz
Edz is on a distinguished road
Mines did the same thing a friend said cam or crank sensor. I changed both and it worked perfectly after that could be one of those.
Old Apr 25, 2018 | 09:55 AM
LesMyer's Avatar
Does the SES light come on with key on engine off? If not, figure out why. If it does come on, figure out why your scanner won't connect. Don't use the S.W.A.G. system of diagnosis!! It will cost you lots of $$$$$!!
95blazin
Jan 15, 2012 04:38 PM
godsmack8626
Sep 28, 2008 02:53 PM
millertimee
Mar 24, 2008 01:32 PM
prototype80
Engine & Internal
Dec 7, 2006 01:38 PM
codereddanger84
Nov 13, 2005 02:52 PM
