96 Blazer Y Pipe Removal ?
Old May 12, 2015 | 12:09 AM
gtmccormick's Avatar
gtmccormick is on a distinguished road
Default 96 Blazer Y Pipe Removal ?
i have a 96 blazer and need to remove the Y pipe to get the transmission out…the bolt nuts are stripped/Frozen does anyone know if I cut them off can I pound the studs out and just replace them
Old May 12, 2015 | 12:28 AM
The bolts in question are the ones going from the ypipe to cat the other came off fine
Old May 12, 2015 | 07:50 AM
El_Beautor's Avatar
I believe you can. I replaced the 3 pressed in bolts on my cat a few years ago by doing that.
Old May 12, 2015 | 09:50 AM
newguy's Avatar
Mapp gas torch will help a lot
Old May 14, 2015 | 01:31 PM
abig84's Avatar
yeah if heating them up and hammering a socket on them dont get them off you can cut them. i believe they are a stud set up if thats the case youre gonna have to heat up the cut stud red hot then hit it out with a hammer hammer, or hammer and chisel if no air hammer is available. i do it on chevy vans all the time i think s10s are the same way
but anytime i try to take off any exhaust nuts no matter how good they look i heat them up, ive broken too many over the years
karmtec
Nov 16, 2014 06:57 PM
flipzat
Dec 19, 2009 09:40 PM
gscrippler
Headers, Intake, & Exhaust
Sep 14, 2009 09:35 AM
marksoftball
Dec 29, 2008 08:27 PM
johnnyblaze
Sep 24, 2006 11:32 PM
