'97 4.3: Intake manifold gasket blown?
![Angry](https://blazerforum.com/forum/images/icons/icon8.gif)
I have a coolant leak in a 97 Blazer 4.3, a bad one, but it is at the front of the engine. I assume it's the intake manifold gasket and from the fact that if I squeeze the upper radiator hose, coolant blasts out of the gap. It's almost like a piece of gasket was busted out as it is so obviously unsealed. Only ran for a few minutes to get gas and then noticed that the fluid had quickly escaped. There is no fluid evident in the oil and I haven't driven it since the fluid drained. Engine runs fine. No white smoke.
Thoughts?
Video also on YouTube:
Thoughts?
Yes, that definitely looks like a blown intake manifold gasket. When you replace it, make sure you get the metal and rubber Fel-Pro set (I don't know the part number off the top of my head) so it doesn't fail again.
