97 4l60e.. trans tech please lookie
Old Nov 14, 2008 | 02:28 PM
Dakota_Don's Avatar
Dakota_Don is an unknown quantity at this point
Default 97 4l60e.. trans tech please lookie
I wasnt for sure how to post a pics so i will attach a link to another site with the photos..
thanks
http://board.moparts.org/ubbthreads/...=1#Post4810870
HI, i am working on a 97 4L60e trans that lost reverse, anyway i found the reaction drum busted..
see pics..
But also found the input housing was scared up a bit, i do not think this will be a problem.. what do you think??
see pics..
here is a list of parts i am going to order
TC will be original but rebuilt..
The beast SHELL
A74624A $45
Overhaul kit 93-97 super master kit with, band and pistons
150
Transgo shift kit correction kit
T74165e
and seperator plate
$38
is there any other upgrades or tips that would be useful for durability??Like firmer TCC apply? a better 2-3 shift??
I also have a4L60E DVD series on the way to..
thanks
Don
Old Nov 14, 2008 | 05:38 PM
Default RE: 97 4l60e.. trans tech please lookie
access denied on your link...
Old Nov 15, 2008 | 02:15 PM
Dakota_Don's Avatar
oh the pics only showed the broken drum, no biggie..
ATSG also recomends that you remove and discard the load and release spring assemblies for a much improved 2-3 shift on all models..
Is this a good idea??
page 62 fig 110 of the atsg manual
http://www.scribd.com/doc/3970579/4L60E-Rebuild-manual-
also look at page 54 number 5 and 6, should I leave this ball out? (ball and capsule)
Old Nov 16, 2008 | 11:40 AM
Hanr3's Avatar
Yes, that figure 110 is correct. I got rid of them almost 2 years ago when I rebuilt my tranny.
If your building a heavy duty tranny, than remove the ball. The capsule must be there either way. My tranny still has the ball.
Old Nov 16, 2008 | 03:16 PM
CoolAirVw's Avatar
CoolAirVw is an unknown quantity at this point
Load release springs on 3-4 clutch.... I will agree that leaving them out will make a firmer 2-3 shift, but to every upside, there is a downside. They are there to keep the 2-3 from "dragging" due to the clutch partially applying due to normal crossleaks, and when the drum spins quickly in 1st and 2nd the centrifugal force makes the oil in drum "fling out" which will also paritially apply the clutchs. 3-4 clutch failure is too common to risk this modification in my opinion. I would find another way to make "firm" 2-3.
TCC check ball and oriface in input shaft. Taking that thing out will definatly make firm TCC! Too harsh in my opinion!
Old Nov 16, 2008 | 06:22 PM
Dakota_Don's Avatar
hello, ty for the replies, i would like to firm up the shifts without sacraficing reliability.. is there any other way to firm the upshifts? or does the computer control to much? also in the atsg manual it also states of enlarging to 1/16 in the piston..
this trans isnt raced, just a daily driver..
thanks
Old Nov 17, 2008 | 04:00 PM
Hanr3's Avatar
The ASTG manual is written for the experts by experts.
Old Nov 17, 2008 | 11:06 PM
Dakota_Don's Avatar
thanks for that expert advice...
Old Nov 18, 2008 | 10:42 PM
CoolAirVw's Avatar
ORIGINAL: Dakota_Don
Corvette servo, larger boost valve and sleeve in the pump. Increase the number of frictions in the 3-4 clutch. Use a beast sun shell as you mentioned, bore and replace the AFL valve to preserve 3-4 clutch and prevent other "mystery" problems. And a good ol' Gil Younger shift kit (transgo as you mentioned). Transgo kit can be used to firm up, most of what you need. One kit had selectable accumulator valve springs, I dont know if thats the one your getting.
I'm not understanding your, "enlarge to 1/16 in the piston". What piston? Enlarge what?
dj00140
22
Nov 4, 2015 05:03 AM
rviolette84
Dec 23, 2012 12:09 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
2klt
Headers, Intake, & Exhaust
Mar 5, 2006 08:38 PM
