97 blazer fuel pump
Old Oct 25, 2009 | 05:41 PM
97 4x4 blazer's Avatar
97 4x4 blazer is on a distinguished road
Default 97 blazer fuel pump
can anyone help me. i have a 97 blazer and someone said the fuel pump was bad. when you turn the key on without engine running it is around 60-62psi. when you start the blazer it runs 52-54psi. if you rev it up the pressure jumps to 60psi. but when you turn the blazer off the pressure holds at 50psi. can anyone give me any ideas? thanks
Old Oct 25, 2009 | 06:20 PM
What seems to be the problem?
Old Oct 26, 2009 | 12:40 AM
bandidolenny's Avatar
Ughhh... sounds normal to me, what symtoms are you having?
Old Oct 26, 2009 | 10:15 AM
Stitch17's Avatar
Stitch17 is on a distinguished road
is 60-62 the pressure when the fuel pump is running? The fuel pressure shouldn't be any lower than 56psi.
Old Oct 26, 2009 | 06:00 PM
the blazer spits and sputters at idle. and sometimes wont start at all. when it dont want to start the fuel pressure wont go above 40psi. theres no leaks. didnt know if the fuel pump was going out. just had tune up,new filter. less than a month ago.
Old Oct 26, 2009 | 08:47 PM
If you only get 40psi at times, then you either have a leak (could be internal to the engine or inside the tank), a bad pump, or a problem with the power supply to the pump. Those are the choices.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
