97 blazer fuel pump
can anyone help me. i have a 97 blazer and someone said the fuel pump was bad. when you turn the key on without engine running it is around 60-62psi. when you start the blazer it runs 52-54psi. if you rev it up the pressure jumps to 60psi. but when you turn the blazer off the pressure holds at 50psi. can anyone give me any ideas? thanks
the blazer spits and sputters at idle. and sometimes wont start at all. when it dont want to start the fuel pressure wont go above 40psi. theres no leaks. didnt know if the fuel pump was going out. just had tune up,new filter. less than a month ago.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
mytruck2
Dec 13, 2006 04:50 PM
