97 Blazer long crank when warm
Old Jun 6, 2012 | 12:41 PM
ojibwe_guy's Avatar
ojibwe_guy is on a distinguished road
Question 97 Blazer long crank when warm
The Blazer cranks longer than it should after its warm when it sits for more than a few minutes. It fires immediately when cold, or when we have a quick return to the vehicle.. almost like it loses fuel pressure. But letting the pump completely stop before turning the starter doesn't help. It cranks about 2-2.5 times "normal" startup, then coughs out a bit of smoke that smells like rich exhaust, not oil and/or coolant.
I could go borrow/buy a pressure tester, but I'm not convinced fuel is the problem. Any suggestions?
Old Jun 6, 2012 | 01:09 PM
50lb_cat's Avatar
What year? If its black smoke then that is unburnt fuel. I would do a fuel pressure and leakdown test. Sounds like a fuel problem. Post back the numbers for key on, engine off and any leakdown after 10 minutes.
Old Jun 6, 2012 | 01:56 PM
ojibwe_guy's Avatar
Pretty sure it is unburnt fuel.
I'll check pressure as soon as I can, may take a few days though. It's a 97 like in the title
Old Jun 6, 2012 | 02:49 PM
50lb_cat's Avatar
Lol sorry I missed that. Is it throwing any codes? May also be a dirty egr valve sticking on you or you just need new plugs but I would still start off with the pressure test. You can try cleaning the egr to see if that helps.
Old Jun 6, 2012 | 04:19 PM
aa21830's Avatar
aa21830 is on a distinguished road
My '96 4.3 would do that...go into a store for 5 minutes, come back out, really hard starting. Usually had to start and stop cranking 3 times before it would fire (but started easily when cold). Replaced the LIM gaskets and all was good again.
shanegreen
May 24, 2012 05:14 PM
TheJuicer
Nov 15, 2010 10:29 AM
Kage0113
Dec 5, 2008 04:14 PM
mnsajt
Apr 20, 2008 02:55 PM
Inferno
Oct 22, 2006 08:56 PM
