97 blazer wont move when press on gas
Old Dec 11, 2017 | 08:03 AM
Logan Ford's Avatar
Logan Ford is on a distinguished road
Default 97 blazer wont move when press on gas
i have a 97 blazer with the 4.3 v6 and im trying to figure out what is wrong with it. i was driving it the other day and it simply didn't want to move when at a light. it reved up then it engaged. it now only engages and moves if i let it sit for an hour but it only goes 20 or 30 ft then it just revs the motor. the motor still stars every time no problem.
Old Dec 11, 2017 | 08:29 AM
LesMyer's Avatar
Sounds like transmission is toast. But check trans fluid level and fill to confirm. Black burnt fluid is bad. Red fluid is good.
Old Dec 11, 2017 | 09:19 AM
'93BLZR's Avatar
'93BLZR is on a distinguished road
Check filter and fluid. sometimes a clogged filter will limit fluid flow and prevent the transmission from working. Although it sounds like the clutches are toast.
Old Dec 11, 2017 | 11:13 AM
I would concur that the clutches could be bad. Do the easy checks first of course.
I was surprised how quickly my transmission went out when my clutches finally failed. It seemed like it was only over the length of a couple weeks that it came on.
Old Dec 11, 2017 | 05:35 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
I agree. The 4L60 doesn't "warn" you the same way the old Turbo 350 & 400 did. My 3/4 clutches failed on me with what I thought was little to no signs of impending failure. The signs are a lot more subtle with these 4 speed auto's.
bertrenolds
Feb 22, 2013 06:24 PM
jward2155
Oct 21, 2011 10:13 PM
DetailersDomain
Detailing
Feb 19, 2011 07:30 PM
1stgen4x4
Sep 12, 2008 07:10 AM
apekim
Sep 15, 2007 10:46 AM
