97 Chevy blazer won't crank over
Old Sep 3, 2017 | 07:46 PM
Dmoney's Avatar
Dmoney is on a distinguished road
Default 97 Chevy blazer won't crank over
I have replace the strategy on it and it still won't crank over
Old Sep 3, 2017 | 07:48 PM
Dmoney's Avatar
Default Neutral safety switch
How do you know when the neutral safety switch goes bad
Old Sep 3, 2017 | 09:03 PM
AJBert's Avatar
If you KNOW the starting system is good, yet will still not turn over or hear the solenoid clicking in park, that's a pretty good indication of a faulty neutral safety switch.
Try putting the vehicle in neutral and starting it. If it starts then it is not the switch but something else...normally.
Old Sep 3, 2017 | 10:35 PM
Dmoney's Avatar
it doesnt start any gear lights come on but no crank and I change the starter but still no crank
Old Sep 4, 2017 | 07:50 AM
GeorgeLG's Avatar
1) Is everything completely dead when you try to start it or do you here the solenoid click or the starter start to engage but will not turn the engine?
2) What is the system voltage at rest and what happens to the system voltage when you turn the key? What happens to the headlights?
3) What is the voltage measured on the big power cable right at the starter at rest and when trying to start?
4) What is the voltage measured right at the starter for the solenoid signal when trying to start?
5) Are there any loose or corroded connections at the battery, large starter cables, or grouns cables?
I don't know the starter circuit on your year so I don't know the relay and solenoid circuit. Maybe someone else can chime in if this does not get you going.
George
Old Sep 4, 2017 | 11:23 AM
Dmoney's Avatar
George
the lights stay on but there's no click from anything when I turn the key but I can start it up if I put a flat head on the starter
Old Sep 4, 2017 | 08:24 PM
Dmoney's Avatar
Could the neutral safety switch kill my battery
Old Sep 5, 2017 | 09:37 PM
AJBert's Avatar
No. It can't.
Buddykitchen
Dec 10, 2016 06:37 PM
amp042
Jun 9, 2013 04:29 AM
mjhoffman48
Mar 1, 2011 12:10 PM
nicocide
Jul 13, 2010 07:57 PM
GotYoNacho
Jan 11, 2009 06:29 PM
