97 s-10 blazer runs rough
Old Mar 4, 2007 | 03:31 PM
samdog21's Avatar
samdog21 is an unknown quantity at this point
Default 97 s-10 blazer runs rough
97 s-10 is running rough. have replaced plugs, wires, cap and rotor. put in new fuel injector. It still runs rough and can smell fuel out of the exhaust. any suggestions?
Old Mar 4, 2007 | 03:54 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
Default RE: 97 s-10 blazer runs rough
Sounds like you have a bad spider valve (fuel injector). I had the same thing happen. I had to change out the unit and I needed a new EGR too.
Old Mar 4, 2007 | 04:05 PM
samdog21's Avatar
thank you
Old Mar 4, 2007 | 06:55 PM
20Blazer00's Avatar
Check all of your vacuum hoses and connections to see if they are either cracked of disconnected.
Check your EGR valve for carbon deposits, clean out passages in manifold if extremely fouled...
Check computer for DTC's to see if there is a sensor or system that is failing to provide computer with the correct data needed to run the system.
Old Mar 5, 2007 | 12:35 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
When you say you put a new fuel injector in, do you mean the whole assembly of 6 injectors, or just one for one cylinder? Also check the compression, and do you have a check engine light?
barnesto
31
Jun 11, 2014 07:12 PM
fnbutch
Jun 25, 2013 12:08 AM
zakm0n
Jan 10, 2011 11:42 AM
sweet-98ta
Jan 5, 2010 12:56 PM
c10jm
Aug 12, 2008 05:34 PM
