98 4.3vortec fresh parts build, got a few questions.
So our 98 4.3 vortec dropped oil pressure and started knocking on the highway doing 60 while she was driving to her grandma's.
I got it yanked and disassembled, it had spun 2 rod bearings and wore out the 2 sets of inner main bearings.
Took it to the machinist fee weks ago. he surfaced and worked the rods and caps, shot peened them, pistons were reinstalled.
Cylinder one crank journal was trashed, 6 was worn but recondition able.
Mains were fine and a new CSS Stroker crank was ordered, along with a Profiled cam from CSS
Ive got everything sitting here now and i am ready to re assemble, I've ran into a issue of how should I aling the cam and balancer, along with the crank shaft?
Dot on the balance shaft gear points down at 6'o clock. Dot on the camshaft gear points up at 12'o clock. Make sure that the dots on each gear are now facing each other.
Afterwards, you install the camshaft sprocket and the crank sprocket. Dot on the camshaft sprocket points down at 6'o clock. Dot on the crankshaft sprocket points up at 12'o clock. Make sure the dots on each sprocket are now facing each other. Now, without disturbing the timing, remove the camshaft sprocket and carefully install the timing chain along with the camshaft sprocket. Your motor is now properly timed.
Awesome!!!!! Thanks a lot wilddomestictabby, I searched the Chilton's, Haynes and my gm tech manual like crazy and couldn't find it, must have over looked it. Even searched Google and s10forum but couldn't couldn't find a definite answer. Love this forum, this group of people is as good as the Z32 community.,
My other question is. In what orientation should the pin and or the two timing marks of my harmonic balancer be in, in relation to the key way shaft groove on the crank shaft balancer pulley?
I've rebuilt a 4.3 before, but the rotating assembly was use able so I had all my marks.
This time around I have no clue, because of the new crank and cam. Thats the reason for the questions lol. Plus I've been deep in the world of Z32's for a couple years so forgot a lot of vortex stuff.
If I understand your question correctly, you want to know which direction timing marks on the harmonic balancer should face before pressing it in? If so, then it doesn't matter. The keyway groove on it only lets it go in one way.
If you'd like to set your ignition timing after installing everything, then you'd want to post the vintage of your truck. The late model ones don't have adjustable timing, other than a slight Crank Offset adjustment with a computer hooked up to monitor change.
It sounds like your balancer is in two pieces and needs replacement.
Bybsurfr32
06-02-2019 04:00 AM
Bybsurfr32
11-01-2009 06:50 PM
