98 blaze transmisson issue
Old May 16, 2011 | 02:51 AM
joshuariann's Avatar
joshuariann is on a distinguished road
Default 98 blaze transmisson issue
I recently inherted a 98 blazer. The problem it has is: it will shift in reverse fine. you put into drive you have to give alot of pedal to get it to move. While in drive on a incline it will hold it's self without brakes applied, if you put into neutral it will free wheel down the incline. any suggstion? Thanks for any help.
Old May 16, 2011 | 06:51 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Which way are you facing on an incline? Facing up or down? It almost sounds like something is broke and causing a lot of drag. Either that or you have a leak in the forward piston. Either one is going to require removal and a repair/rebuild.
Old May 17, 2011 | 07:29 AM
Thanks for responding. It would be facing down hill. Gonna take out transmission this weekend and replace with rebuilt one. let you know what happens. once again thanks for your help not good with transmissions lol
S10BlazerFTW
Apr 26, 2013 04:43 PM
rjck1979
Dec 29, 2009 04:15 PM
99 Blazer 4 door
Performance & Brainstorming
Aug 29, 2008 10:46 AM
SoDakBlazer
Aug 5, 2006 06:21 PM
BlaZeR FXB1581
Engine & Internal
Jan 27, 2006 07:45 PM
