98 blazer fuel regulator this aint right. is it?
Old Mar 25, 2013 | 05:46 PM
forrestfire's Avatar
forrestfire is on a distinguished road
Talking 98 blazer fuel regulator this aint right. is it?
98 4.3 w vin. 4wd. 4-door.
pulled plenium off to change the reg. and noticed hey? where the heck is the vac. line? is this right? nipple where vac. line is supposed to attached is all coroided plugged up an such. dont understand. if this is how its supposed tobe. how does it reg. press. ? someone has been inside the plenium before me .bolts loose etc. problem to begin with was drive fine an all. untill after 50-75 miles. then it start starving for fuel at any acceleration let off throttle a little and it would clean up. pull over cycle the key a few times run fine for about 30 miles or so.lower fuel level sooner it would start happening. replaced fuel pump.(delco) pressure test are all within spec .leak down was a little fast didn't hold very long.now it wont stay running. so next was o-rings an reg. dont have enough for spyder an such. as things are tight. you know? funny thing about it is this had to happen on my way to a job interview this morning. horoscope said dont let dark clouds darken your day. BULL.... !!!!
its hazey warm in california today. DUDE was understaning about interview. wants to talk to me before he decides. COOL !
SOOOOO HEEELLLLPP! PLEASE. NEW TO SITE BUT LEARN SOMETHINGS OVER THE WEEKEND. thanking someone in advance for there help.
Old Mar 25, 2013 | 06:09 PM
Default nevermind
found answer in a differant post. makes sence now. posted today. wow sky is getting clearer.
ericthughes
May 17, 2012 09:03 PM
ericthughes
Nov 2, 2011 09:27 PM
2002XTREME
Feb 2, 2009 06:01 PM
thejoshx420
Nov 21, 2007 09:18 AM
jlinder
Aug 21, 2005 11:08 AM
